Enables MLD snooping on the switch.
| vlan_name | Specifies a VLAN. |
Disabled.
If a VLAN is specified, MLD snooping is enabled only on that VLAN, otherwise MLD snooping is enabled on all VLANs.
A VLAN must have an IPv6 address to support MLD.
The following command enables MLD snooping on the switch:
enable mld snooping
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
